Beginner Guide to Javascript and Widgets
1520
7
01-07-2021 02:20 AM
higgy7
New Contributor III
I am a complete newbie to Javascript, I normally use WAB and WAB Developer. Is there anyway to use the point clustering talked about in this blog:
https://www.esri.com/arcgis-blog/products/js-api-arcgis/mapping/summarize-and-explore-point-clusters...
Within WAB? I don't think I have the access to install  ArcGIS API for JavaScript . Is there someway to put this:
https://developers.arcgis.com/javascript/latest/sample-code/featurereduction-cluster/index.html
In a widget and bring it into WAB for the user to use.
Thanks in advance!
shaylavi
Both links refers to the javascript API version 4.x. WebApp Builder is based on version 3.x of the API.
So referring to what presented in the links, the answer is no. You can however, use the available cluster options available for version 3 of the API as explained here - https://developers.arcgis.com/javascript/3/jssamples/layers_point_clustering.html
And of-course the functionality can be wrapped as part of a widget in the Dev' edition.
Shay
higgy7
New Contributor III
Hi Shay,
Thanks for the quick response. Is there any guide on how to do this? For example when i download the info from that link, the folder structure is as follows:
The apps i would use have a structure similar to this:
Are there other steps i would have to take? Sorry about my lack of knowledge!
shaylavi
I don't really understand what you're trying to achieve.
If it's just to display a layer as clusters, you don't need a widget or WAB, you just configure the layer to be shown as cluster layer through a webmap at Portal and consume that layer as you do through WAB.
If you would like to build a new custom widget that will display a layer/data as clusters that's quite an effort and you need to learn how to create custom widgets first and there are many guides to this that can help you, but it sounds like you just want to configure a layer with cluster symbology through a webmap on Portal.
Shay
higgy7
New Contributor III
What i would have liked is to have a widget where the user could display the data as clusters but you have stated what i thought that i would have learn how to create custom widgets.
To display the layer with cluster symbology through a webmap on Portal is this just using the heatmap symbology or is there another way to symbolise?
shaylavi
For a point layer there should be a separate button to define a cluster view of the layer - it's not part of the symbology config screen you mentioned that lets you choose a heatmap view.
For a polygon/polyline, you should be able to see the clustering setting under that symbology config window.
If you're just learning on custom widgets, I would start with the basics before jumping to showing a cluster layer -
The widget will need to be hosted on an IIS server at some point if you're publishing it to users so that's also something to be aware of and see if you can even do that (host it on an IIS server).
Once you create a widget and add it, you can add a button and then see if you can add a new layer to the map with a button click, which then you'll be able play-around and applying different symbologies or renderers to that layer.
Shay
higgy7
New Contributor III
Prefect thanks again for all the help. I have used custom widgets that other users have created so I am familiar with hosting on an IIS server etc.
Once again thanks for the help and information!
shaylavi
Good luck
Shay
