beginner: changing map extent on click
503
11-03-2011 08:09 AM
MikeOnzay
Occasional Contributor III
I want the map extent to change by clicking on some text. I'm using the example Add Dynamic Map and I have added the following code
function myzoom() {
        var axtent = new esri.geometry.Extent(55.6153456, 5.7191691, 105.6673614, 37.0016790, map.SpatialReference);
        map.setExtent(axtent);
I have tried placing it both outside of the init function and inside the init function. In both cases I get an error when I call it
<p id="test" onClick="myZoom();">click for zoom</p>
If I add an alert function outside of the init function
  function nTest(){
   alert("test2");
and call it from here
<p id="test2" onClick="nTest();">click for alert</p>
it works.
Why?
- Mike
derekswingley1
JavaScript is case-sensitive. Your function name is "myzoom" but your onClick says "myZoom".
I probably should have posted a more complete code sample in the other thread where this was recently discussed. Here's a simple page demoing this:
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
    <title>Zoom to Extent Test</title>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css">
  <script type="text/javascript">djConfig = { parseOnLoad: true }</script>
    dojo.require("esri.map");
    var map, layer;
    function Init() {
      map = new esri.Map("mapDiv");
      layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapServer");
      map.addLayer(layer);
      dojo.connect(dojo.byId('button2'), 'onclick', myzoom);
    function myzoom() {
      console.log('my zoom fired');
      // var axtent = new esri.geometry.Extent(105.6673614, 37.0016790, 55.6153456, 5.7191691, map.SpatialReference);
      console.log('xmin: ', axtent.xmin, '; ymin: ', axtent.ymin);
    dojo.ready(Init);
  </script>
</head>
<body class="tundra">
  <div id = "mapDiv" style="width:800px; height:300px"> </div>
  <input id="button2" type="button" value="Zoom To India" />
</body>
</html>
MikeOnzay
Thanks for posting the complete code from the other post.
I caught that case sensitivity after I published my original post.
When I fixed my function name problem I still got an error that myZoom was not defined. I see from your example that while I placed my function in the head section I did not tie it together with dojo.connect.
I found that it in the dojo.connect that you can use either
dojo.byId('button2') or just button2 in the dojo.connect statement. Is this a matter of preference or is there a reason why you were more specific?
The reason why I coded the way I did was because I had looked at this example and I saw that there was an onChange event in the combobox. It calls a function which changes the map based on a layer definition. So I thought it would be okay to do something similar with an onClick event.
Why does this example not use a dojo.connect statement to tie it together as you showed in my original example?
derekswingley1
I prefer to use dojo.connect() to wire up events as it keeps JavaScript separate from HTML. I do not like to embed JS in my markup. Separation of concerns and all that...
For the first argument to dojo.connect, I prefer using dojo.byId() because it's explicit what is happening. It's perfectly reasonable to just use a string that corresponds to a DOM node's ID.
MikeOnzay
Thanks for your help and clear explanations.
