Basemap Dropdowns do not show labels
547
06-02-2017 09:48 AM
SarojThapa1
I am trying to display basemaps gallery as dropdowns. The dropdown menu displays a bunch of dropdowns. If I click them, the basemap changes.
js:
var dynamicLayer = new ArcGISDynamicMapServiceLayer("https://RESTURL/MapServer");
map.addLayers([dynamicLayer]);
map.on('load', function () {
createBasemapGallery();
function createBasemapGallery() {
//console.log("Basemap");
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: true,
map: map
basemapGallery.startup();
connect.connect(basemapGallery, 'onLoad', function () {
array.forEach(basemapGallery.basemaps, function (dynamicLayer) {
registry.byId("basemapMenu").addChild(new MenuItem({
label: dynamicLayer.title,
onClick: function () {
basemapGallery.select(dynamicLayer.id);
  html:
<div style="position:absolute; right:320px; top:145px; z-Index:1;">
  <button id="dropdownButton" label="---Select a Basemap---"  data-dojo-type="dijit/form/DropDownButton">
  <div data-dojo-type="dijit/Menu" id="basemapMenu">
</div>
</button>
</div>
ChrisSmith7
This is absolutely not clean, just a quick POC for you, but it's a complete working example for what I think you're trying to do:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title>Basemap gallery</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.20/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
  <style>
    html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    #map{
      padding:0;
  </style>
  <script src="https://js.arcgis.com/3.20/"></script>
  <script>
    var map;
    require([
      "esri/map",
      "esri/dijit/BasemapGallery",
      "esri/arcgis/utils",
      "dojo/parser",
      "dojo/_base/connect",
      "dijit/MenuItem",
      "dojo/_base/array",
      "dijit/registry",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dijit/TitlePane",
      "dojo/domReady!"
    ], function(
      Map, BasemapGallery, arcgisUtils,
      parser, connect, MenuItem, array, registry
      parser.parse();
      map = new Map("map", {
        basemap: "topo",
        center: [-105.255, 40.022],
        zoom: 13
      //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
        map: map
      }, "basemapGallery");
      basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer"
       data-dojo-props="design:'headline', gutters:false"
       style
="width:100%;height:100%;margin:0;"
    <div id="map"
         data-dojo-type="dijit/layout/ContentPane"
         data-dojo-props="region:'center'"
         style
="padding:0;"
          <div data-dojo-type="dijit/Menu" id="basemapMenu"></div>
        </button>
      </div>
      <div style="position:absolute; right:20px; top:10px; z-Index:999; display:none;">
        <div data-dojo-type="dijit/TitlePane"
             data-dojo-props="title:'Switch Basemap', closable:false, open:false">
          <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
            <div id="basemapGallery"></div>
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
ChrisSmith7
<!DOCTYPE html>
<html>
<head>
  <style>
    #map{
      padding:0;
  </style>
  <script>
    var map;
    require([
      "esri/map",
      "dojo/parser",
      "dijit/MenuItem",
      "dojo/_base/array",
      "dijit/registry",
      "dijit/TitlePane",
      "dojo/domReady!"
    ], function(
      parser.parse();
        basemap: "topo",
        zoom: 13
        map: map
  </script>
</head>
       style
    <div id="map"
         style
="padding:0;"
        </button>
      </div>
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
SarojThapa1
Thank you Chris.
