Avoid Hightlight Graphic when infowindow shows
2272
5
10-13-2015 08:42 AM
JulieBiju
Hai , Thank U...
Is it possible to avoid highliting the graphic in blue colour when the information windows shows.I am using picture marker symbol so for some of the images will give wrong information to users.
Eg :   Extend Popup
               var infoTemplate = new InfoTemplate();
                infoTemplate.content = strhotspot;
                var pointGraphic = new Graphic(geomPoint, symbol);
                pointGraphic.setInfoTemplate(infoTemplate);
                MyGraphicsLayerGL.add(pointGraphic);
RobertScheitlin__GISP
Julie,
  Here is your app with the highlight gone:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <!--The viewport meta tag is used to improve the presentation and behavior
    of the samples on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Basemap Gallery - Bing Maps</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
  <style type="text/css">
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      z-index: -1;
      -moz-border-radius: 4px;
      overflow: hidden;
    .claro .dijitButtonText {
      color: #03c;
      font-family: Arial, Helvetica, sans-serif font-weight: bold;
    .claro td.dijitMenuItemLabel {
      color: #03c;
      font-family: Arial, Helvetica, sans-serif font-weight: 500;
    .auto-style1 {}
    .auto-style2 {
      height: 20px;
    .auto-style3 {
      height: 20px;
    .auto-style6 {
      height: 2%;
      width: 279px;
    .auto-style7 {
      width: 279px;
    #TxtAltareeqEng {
      width: 55px;
    #TxtAltareeqEng0 {
      width: 55px;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: false,
      async: true,
      tlmSiblingOfDojo: false,
      packages: [{
        location: location.pathname.replace(/\/[^/]+$/, '') + "/ncam"
  </script>
  <script type="text/javascript" src="http://js.arcgis.com/3.14/"></script>
  <script type="text/javascript">
    window.onerror = function (msg, url, linenumber) {
      alert('Error message: ' + msg + '\nURL: ' + url + '\nLine Number: ' + linenumber);
      return true;
    var map, basemapGallery, loading;
    require([
        "esri/map",
        "esri/graphic",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/GraphicsLayer",
        "esri/geometry/Extent",
        "esri/geometry/Point",
        "esri/geometry/Polyline",
        "esri/SpatialReference",
        "esri/symbols/PictureMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/dijit/Popup",
        "dojo/dom-construct",
        "esri/dijit/PopupTemplate",
        "esri/dijit/Basemap",
        "esri/dijit/BasemapGallery",
        "esri/dijit/BasemapLayer",
        "esri/graphicsUtils",
        "esri/domUtils",
        "dojo/_base/array",
        "dojo/parser",
        "dojo/dom",
        "dojo/_base/lang",
        "dojo/dom-style",
        "dijit/MenuItem",
        "dijit/registry",
        "ncam/DirectionalLineSymbol",
        "dijit/Menu",
        "dijit/layout/ContentPane",
        "dijit/form/Button",
        "dijit/form/RadioButton",
        "dijit/form/DropDownButton",
        "dojo/domReady!"
      function (
        Map,
        Graphic,
        ArcGISDynamicMapServiceLayer,
        GraphicsLayer,
        Extent,
        Point,
        Polyline,
        SpatialReference,
        PictureMarkerSymbol,
        SimpleLineSymbol,
        Popup,
        domConstruct,
        PopupTemplate,
        Basemap,
        BasemapGallery,
        BasemapLayer,
        graphicsUtils,
        domUtils,
        array,
        parser,
        dom,
        lang,
        domStyle,
        MenuItem,
        registry,
        parser.parse();
        var TareeqENG, TareeqARB;
        var graphicsLayer;
        var AltareeqArb, AltareeqEng;
        loading = dom.byId("loadingImg");  //loading image. id
        var popup = new Popup({
          highlight : false
        }, domConstruct.create("div"));
        map = new Map("mapDiv", {
          center: [6.389, 36.054],
          zoom: 4,
          basemap: 'topo',
          autoResize: false,
          infoWindow: popup
        map.on("update-start", showLoading);
        map.on("update-end", hideLoading);
        map.on('load', function() {
          createBasemapGallery();
        registry.byId("radioOne").on("change", function(isChecked){
          if(isChecked){
            registry.byId("LnkLastPosition").set("label", "LastPosition");
            registry.byId("LnkTracking").set("label", "Tracking");
        }, true);
        registry.byId("radioTwo").on("change", function(isChecked){
          if(isChecked){
            registry.byId("LnkLastPosition").set("label", "الموقف الأخير");
            registry.byId("LnkTracking").set("label", "التتبع");
        }, true);
        registry.byId("LnkLastPosition").on("click", LastPosClick);
        registry.byId("LnkTracking").on("click", LastPosClick);
        function showLoading() {
          domStyle.set(registry.byId("dropdownButton").domNode, "display", "none");
          domUtils.show(loading);
          map.disableMapNavigation();
          map.hideZoomSlider();
        function hideLoading(error) {
          domStyle.set(registry.byId("dropdownButton").domNode, "display", "");
          domUtils.hide(loading);
          map.enableMapNavigation();
          map.showZoomSlider();
        function createBasemapGallery() {
          AltareeqEng = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapSer...";
          AltareeqArb = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer";
          //Manually create a list of basemaps to display
          var basemaps = [];
          TareeqENG = new Basemap({
            layers: [new ArcGISDynamicMapServiceLayer(AltareeqEng)],
            title: "Al-Tareeq(ENG)"
          basemaps.push(TareeqENG);
          TareeqARB = new Basemap({
            layers: [new ArcGISDynamicMapServiceLayer(AltareeqArb)],
            title: "Al-Tareeq(AR)"
          basemaps.push(TareeqARB);
          BingMapsRoad = new Basemap({
            layers: [new BasemapLayer({
              type: "BingMapsRoad"
            title: "BingMaps-Road"
          basemaps.push(BingMapsRoad);
          BingMapsAerial = new Basemap({
              type: "BingMapsAerial"
            title: "BingMaps-Aerial"
          basemaps.push(BingMapsAerial);
          BingMapsHybrid = new Basemap({
              type: "BingMapsHybrid"
            title: "BingMaps-Aerial-Labels"
          basemaps.push(BingMapsHybrid);
          basemapGallery = new BasemapGallery({
            showArcGISBasemaps: false,
            basemaps: basemaps,
            bingMapsKey: "ApQMgAf0l5kH5_mfhDmDX1q9DOa1eqAw15N9knkX4sj1kbAoOYzJMNCln6w5t3bs",
            map: map
          basemapGallery.startup();
          graphicsLayer = new GraphicsLayer();
          map.addLayer(graphicsLayer);
          graphicsLayer.on("mouse-over", function (event) {
            var graphic = event.graphic;
            map.infoWindow.highlight = false;
            map.infoWindow.setFeatures([graphic]);
            map.infoWindow.show(event.screenPoint);
          graphicsLayer.on("mouse-out", function () {
            map.infoWindow.hide();
          //BasemapGallery.startup isn't needed because we aren't using the default basemap, instead
          //we are going to create a custom user interface to display the basemaps, in this case a menu.
          array.forEach(basemapGallery.basemaps, function (basemap) {
            //Add a menu item for each basemap, when the menu items are selected
            registry.byId("bingMenu").addChild(new MenuItem({
              label: basemap.title,
              onClick: lang.hitch(this, function () {
                this.basemapGallery.select(basemap.id);
          /*Select that basemap that you want to be initially displayed*/
          basemapGallery.select(TareeqENG.id);
        function LastPosClick() {
          var colourstyle = "images/sphere-blue-dark-16x16.png"
          var Status = "status";
          var procname = "procname";
          var location = "location";
          var Driver = "Drv";
          var strhotspot = "strhotspot";
          var geomPoint1 = new Point(58.46236, 23.61581);
          var geomPoint2 = new Point(59.46236, 23.61581);
          var geomPoint3 = new Point(60.43362666666, 23.583081666666);
          var polyline = new Polyline(new SpatialReference(4326));
          polyline.addPath([geomPoint1,geomPoint2,geomPoint3]);
          var symbol = new PictureMarkerSymbol({
            "url": colourstyle,
            "height": 16,
            "width": 16,
            "type": "esriPMS"
          //add a basic polyline
          var basicOptions = {
            style: SimpleLineSymbol.STYLE_SOLID,
            color: new dojo.Color([0, 0, 0]),
            width: 2,
            directionScale: 0.8,
            directionStyle: "arrow3",
            directionPixelBuffer: 80
          var basicSymbol = new DirectionalLineSymbol(basicOptions);
          var popupTemplate = new PopupTemplate();
          popupTemplate.content = strhotspot;
          var pointGraphic = new Graphic(geomPoint1, symbol);
          var pointGraphic2 = new Graphic(geomPoint2, symbol);
          var pointGraphic3 = new Graphic(geomPoint3, symbol);
          var lineGraphic = new Graphic(polyline, basicSymbol);
          pointGraphic.setInfoTemplate(popupTemplate);
          pointGraphic2.setInfoTemplate(popupTemplate);
          pointGraphic3.setInfoTemplate(popupTemplate);
          graphicsLayer.add(pointGraphic);
          graphicsLayer.add(pointGraphic2);
          graphicsLayer.add(pointGraphic3);
          graphicsLayer.add(lineGraphic);
          setextent();
          var DivesriLogoImage = dom.byId('DivesriLogoImage');
          var mapDiv = dom.byId('mapDiv');
          mapDiv.style.visibility = "visible";
          DivesriLogoImage.style.visibility = "hidden";
        function setextent() {
          var gextent = graphicsUtils.graphicsExtent(graphicsLayer.graphics).expand(1.2);
          map.setExtent(gextent);
  </script>
</head>
<body class="claro">
  <form id="form1" >
    <div style="width: 100%; height: 100%">
      <table id="Tablecontrols0" style="font-size: 15px; z-index: 101; background-color: #5B748B; width: 100%; height: 100%;">
        <tr style="font-family: Times New Roman">
          <td style="border-style: none; background-color: #496277; " valign="top" class="auto-style6">
            <input type="radio" data-dojo-type="dijit/form/RadioButton" name="uilanguage" id="radioOne" checked value="English"/><label for="radioOne">English</label><br />
            <input type="radio" data-dojo-type="dijit/form/RadioButton" name="uilanguage" id="radioTwo" value="العربية"/><label for="radioTwo">العربية</label>
          </td>
          <td align="left" style="border-style: none; background-color: #496277; height: 2%;" valign="top" class="auto-style3">
          </td>
        </tr>
          <td style="border-style: none;" valign="top" bgcolor="#496277" class="auto-style7">
            <table id="Tablecontrols" style="border-color: #F2F0EE; font-size: 15px; z-index: 101;
            background-color: #496277; width:auto; height: 274px; font-family: verdana; color: tomato; font-weight: bold; border-top-style: none;" align="left">
                <td rowspan="1" valign="top" height="10px" class="auto-style1">
                </td>
                <td rowspan="1" style="border-style: none;" valign="top" height="10px">
                </td>
              </tr>
                <td rowspan="1" style="font-weight: bold; " valign="top" height="10px" class="auto-style1">
                </td>
                </td>
              </tr>
                <td style="font-weight: bold; " valign="top" height="10" class="auto-style1" colspan="2">
                </td>
              </tr>
                <td style="font-weight: bold; text-align: center; " valign="top" class="auto-style2">
                  <button dojotype="dijit/form/Button" id="LnkLastPosition" style="font-family: Arial; font-size: x-small; font-weight: normal">
                    Last Position</button>
                </td>
                <td style="border-style: none; text-align: center;" valign="top" class="auto-style3">
                  <button dojotype="dijit/form/Button" id="LnkTracking" style="font-family: Arial; font-size: x-small; font-weight: normal">
                    Tracking</button>
                </td>
              </tr>
                <td colspan="2" rowspan="1" style="border-top: 2px solid #547289; border-bottom: 2px solid #547289; font-weight: bold;  position: static;
                    height: 100%; text-align: left; width: 30%; border-left-width: 2px; border-right-width: 2px;" valign="top" align="left">
                  <div id="Something"></div>
                  <div style="width: 300px; height: 356px; overflow: scroll"></div>
                </td>
              </tr>
            </table>
          </td>
          <td style="border-style: none; background-color: white;  width: 100%; height:100%;" valign="top" id="td11">
            <div id="mapDiv"  dojotype="dijit/layout/ContentPane" region="center" style="border:1px solid #000; visibility: visible; height: 100%;">
              <img id="loadingImg" src="images/loading.gif"
                   style="position:absolute; right:512px; top:277px; z-index:100; width: 40px; height: 40px;" />
              <div style="position:absolute; right:50px; top:100px; z-Index:99;">
                <button id="dropdownButton" label="Basemaps" data-dojo-type="dijit/form/DropDownButton" style="display: none;">
                  <div data-dojo-type="dijit/Menu" id="bingMenu">
                    <!--The menu items are dynamically created using the basemap gallery layers-->
                  </div>
                </button>
              </div>
            </div>
            <div id="DivesriLogoImage"
                 style="background-color: #FFFFFF; width: 80%; height:99.8%; visibility: hidden; position: absolute; top: 72px;" align="center">
            </div>
          </td>
        </tr>
      </table>
    </div>
  </form>
</body>
</html>
Julie,
   Just use this code:
JulieBiju
Hi Robert,
I tried in the following way.But not success.
        map.graphics.clear();  //use the maps graphics layer as the highlight layer
        /*map.infoWindow.setContent(graphic.getContent());
        map.infoWindow.setTitle(graphic.getTitle());*/
        var highlightGraphic = new Graphic(graphic.geometry, graphic);
        map.graphics.add(highlightGraphic);
        map.infoWindow.show(event.screenPoint, InfoTemplate());
Julie,
<!DOCTYPE html>
<html>
<head>
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      z-index: -1;
      overflow: hidden;
      color: #03c;
      color: #03c;
    .auto-style1 {}
    .auto-style2 {
      height: 20px;
    .auto-style3 {
      height: 20px;
    .auto-style6 {
      height: 2%;
      width: 279px;
    .auto-style7 {
      width: 279px;
    #TxtAltareeqEng {
      width: 55px;
    #TxtAltareeqEng0 {
      width: 55px;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: false,
      async: true,
      packages: [{
  </script>
      return true;
    require([
        "esri/map",
        "esri/graphic",
        "esri/dijit/Popup",
        "esri/domUtils",
        "dojo/_base/array",
        "dojo/parser",
        "dojo/dom",
        "dojo/_base/lang",
        "dojo/dom-style",
        "dijit/MenuItem",
        "dijit/registry",
        "dijit/Menu",
        "dojo/domReady!"
      function (
        Map,
        Graphic,
        GraphicsLayer,
        Extent,
        Point,
        Polyline,
        SpatialReference,
        SimpleLineSymbol,
        Popup,
        domConstruct,
        PopupTemplate,
        Basemap,
        BasemapGallery,
        BasemapLayer,
        graphicsUtils,
        domUtils,
        array,
        parser,
        dom,
        lang,
        domStyle,
        MenuItem,
        registry,
        parser.parse();
        var graphicsLayer;
          highlight : false
          zoom: 4,
          basemap: 'topo',
          autoResize: false,
          infoWindow: popup
          if(isChecked){
        }, true);
          if(isChecked){
        }, true);
          var basemaps = [];
            basemaps: basemaps,
            map: map
          var Driver = "Drv";
            "url": colourstyle,
            "height": 16,
            "width": 16,
            "type": "esriPMS"
            width: 2,
          setextent();
  </script>
</head>
  <form id="form1" >
          </td>
          </td>
        </tr>
                </td>
                </td>
              </tr>
                </td>
                </td>
              </tr>
                </td>
              </tr>
                </td>
                    Tracking</button>
                </td>
              </tr>
                </td>
              </tr>
            </table>
          </td>
                  </div>
                </button>
              </div>
            </div>
            </div>
          </td>
        </tr>
      </table>
    </div>
  </form>
</body>
</html>
JulieBiju
U R Really Gr8...
thejuskambi
The Popup class has a highlight propertry which can be used to highlight the features or not.
