AreaMeasurement2D
709
01-10-2019 05:50 AM
AbdelrahmanAbdelrazek
I'm using esri js api v 4.10. and when i use the area measurement widget ( AreaMeasurement2D ) the result is not correct in Auto mode (planar mode as i measure features have perimeter less than 100 km) but when i switch the mode  to geodesic the area is semi accurate.
Pls find attached files.
The real area for this polygon is (479.304 Arces).
Thanks in advance.
Noah-Sager
Hi Abdelrahman Abdelrazek, the geodesic mode is the more appropriate (accurate) mode in this scenario. From our doc:
"When using input geometries with a spatial reference of either WGS84 (wkid: 4326) or Web Mercator, it is best practice to calculate areas using geodesicArea()."
geometryEngine | API Reference | ArcGIS API for JavaScript 4.10
We will be updating the behaviors of the 2D measurement widgets in the upcoming release to make this less confusing. Hope this helps.
-Noah
Noah-Sager
-Noah
Thank you so much for this clarification.
Noah Sager
