ArcGIS Server blocks the request to services
4056
10
04-18-2018 04:13 AM
MonikaJovanova
Hi everyone,
I have developed GIS application using the CMV template and I have a created simple html page to validate some data using Feature Tables, which are linked.
Once I select data to review in the CMV application,  I open new window with map and Feature table on it, the request to the feature service is blocked by the ArcGIS Server and none of the services are loading to the map.
I've logged into the ArcGIS Server Manager where I got this error :  "Result limit: 10 reached; ignoring any remaining objects in the query result for Layer: LayerName1"
and similar error for another service "Result limit: 50 reached; ignoring any remaining objects in the query result for Layer:LayerName2"
In the browser, in the Network tab, I check the request but I got the following error : "Could not access any server machines. Please contact your system administrator. "
So, any ideas how to solve this problem or maybe some workaround approach to fixed it?
Regards,
Monika
TaraPreston
New Contributor III
Any solution at this point? I'm having the same issue.
