ArcGIS Javascript API iOS 8 and Dojo Page Transitions
1181
09-19-2014 11:44 AM
ScottRutzmoser2
New Contributor III
We have an ArcGIS JavaScript map that is published using the esri packaged dojo v1.9 and the latest release of iOS 8 breaks the dojo clicks and page transitions.
If you have had access to iOS 8 it is a known issue (#18168 (support iOS8) – Dojo Toolkit )
It breaks our map application (Buses )
AND
Also breaks esri samples (Find Nearby )
Anyone have any suggestions for a work around or maybe does esri plan to build this patch into a current/future release of the JavaScript API
I did a little bit of digging and testing and it doesn't seem like it is feasible to swap out the patched version of the dojo libraries on a hosted version of the JavaScript API
I am using v 3.6 in this application but would happily upgrade if a fix was posted.
Any help is appreciated.
KellyHutchins
Esri Frequent Contributor
Scott,
3.11 should be out early next week so it might be worth waiting for the release?
KellyHutchins
The fix for this will be in the next release of the JSAPI - version 3.11 which is due out in the next few weeks.
ScottRutzmoser2
New Contributor III
Thanks Kelly,
Do you know of any documentation that may help us roll the patch into our hosted version (3.10) of the JSAPI?
Our users are heavy iOS users and we are starting to get reports of our app breaking with the recent iOS upgrade.
(or maybe a beta version of 3.11)
We have actually started to to work around the issue using JQM instead of Dojo, but a local patch would be much quicker.
Thanks Again,
Scott
KellyHutchins
Scott,
JeffPace
ohhh 3.11 hint
