ArcGIS API for JavaScript 4.6 - referenceLayers
883
02-01-2018 11:26 PM
Zdenekprocner
hello,
I have a question about Basemap - JS API 4.
My TileLayer has LODs 0 - 19. The last three LODs are empty (on purpose).
I create the Basemap and
1- The API v. 3 has a map of all LODs - I can also zoom into empty levels (0-19 LOD)
2 -The API v. 4.6 has a map of only non-empty levels (LOds)
When I use it in Basemap properties referenceLayers,it does not work. I have it again  (0-16 LOD)
layer_for_DISPLAY = new TileLayer({
        url: "http://xxxxx/MapServer",
        title: "myName_1"
/*LODs 0 - 19, last three LODs are empty */
layer_for_LODs = new TileLayer({
        url: "http://yyyyyy/MapServer",
        title: "myName_2"
/*LODs 0 - 19, non empty LODs */
/* JS API 4 */
myBasemap = new Basemap({
        baseLayers: [layer_for_DISPLAY],
 referenceLayers: [layer_for_LODs],
        title: "myNameBM",
        thumbnailUrl: ""
Is it wrong?
The reason is that I after load  (dynamic) MapImageLayer, which is displayed on all scale.
Thank you,
Zdenek Procner
RobertScheitlin__GISP
Zedenek,
   You can set the maps constraints lods property to contain the lods you want:
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#constraints
Zedenek,
Zdenekprocner
Hello Robert,
You are right.
app.mapView.constraints.lods  = layer_for_LODs.tileInfo.lods
It is interesting that layer "layer_for_DISPLAY" (TileLayer)  only in empty Lods is behaving as MapImageLayer and it is rendered
Zdenek
