Hello there,
I am attempting to apply a HeatMap renderer to a dynamic layer I have created. The DynamicLayer contains a point query gathered from my ArcGIS Server SDE database.
I have successfully implemented basic things such as SimpleRenderer to display the data on my map. However, whenever I attempt to use the same logic, but swap out the SimpleRenderer with HeatMapRenderer, I get errors. I am sure I am setting all parameters correctly as described in the Documentation Samples.
I am getting the following error reply from my ArcGIS Server: ":"Invalid renderer specified for dynamic dataLayer with 'id': 0."
My code is below: any help would be appreciated.
var dndSource, layerLookup, dynamicLayerInfos;
(function() {
var layerName, dataSource, layerSource, options, drawingOptions;
debugger;
///Testing Renderer
var heatmapRenderer = new HeatmapRenderer({
blurRadius: 10,
colorStops: [
{ ratio: 0, color: "rgba(250, 0, 0, 0)" },
{ ratio: 0.6, color: "rgb(250, 0, 0)" },
{ ratio: 0.85, color: "rgb(250, 150, 0)" },
{ ratio: 0.95, color: "rgb(255, 255, 0)" }],
var m_renderer = heatmapRenderer;
var m_queryDataSource = new QueryDataSource();
m_queryDataSource.workspaceId = biodWeb.const.gis.workSpaceID;
m_queryDataSource.geometryType = "point";
m_queryDataSource.oidFields = ["OBJECTID"];
m_queryDataSource.query = "Select OBJECTID, Shape from bioDWEB.BD.NATEARTH_10M_POPULATED_PLACES";
m_queryDataSource.spatialReference = new SpatialReference({ wkid: 102100 });
var layerSource = new LayerDataSource();
layerSource.dataSource = m_queryDataSource;
//---------- Dynamic layer
layerName = "add a new layer from database";
var usaLayer = new ArcGISDynamicMapServiceLayer("http://MYSERVER.COM/arcgis/rest/services/BiodWebDyn/BioD_DynamicMap/MapServer",
{ "id": "NEW LAYER" });
usaLayer.setVisibleLayers([0]);
if (!dynamicLayerInfos) {
dynamicLayerInfos = usaLayer.createDynamicLayerInfosFromLayerInfos();
var dynamicLayerInfo = new DynamicLayerInfo();
dynamicLayerInfo.id = 0;
dynamicLayerInfo.name = layerName;
dynamicLayerInfo.source = layerSource;
dynamicLayerInfos.push(dynamicLayerInfo);
usaLayer.setDynamicLayerInfos(dynamicLayerInfos, true);
drawingOptions = new LayerDrawingOptions();
drawingOptions.renderer = m_renderer;
options = [];
options[0] = drawingOptions;
usaLayer.setLayerDrawingOptions(options);
map.addLayer(usaLayer);
Did you get a solution to your problem? Were you able to apply a HeatMapRenderer to a ArcGisDynamicMapServiceLayer instead of a FeatureLayer?
Thanks.
