API key setting in Angular
1415
06-18-2021 10:16 AM
PaoloF
New Contributor III
Hi everyone into Community.
I would like to know how to configure API key in Angular application to be able to load prganization materila produced with ArcGIS Pro, in particular TileLayers.
I have tried with this piece of code
ngOnInit() {
    //use esri-loader to load JSAPI modules
    return loadModules([
      'esri/config',
      'esri/Map',
      'esri/views/MapView',
      'esri/Graphic',
      'esri/widgets/BasemapToggle',
      'esri/widgets/BasemapGallery'
      .then(([ config, Map, MapView, BasemapToggle, BasemapGallery, Graphic]) => {
        const esriConfig = new config({
           apiKey: "<MY KEY>"
but when no map loads.
Any suggestion?
Thanks in advance, best regards.
Noah-Sager
Hi @PaoloF, this shouldn't be an issue with Angular, but the issue might have to do with how you are using apiKeys. Can you share a simple reproducible test-app with JavaScript that shows how you are trying to use an apiKey? Also, are the resources hosted in ArcGIS Online?
https://developers.arcgis.com/javascript/latest/release-notes/#api-keys
PaoloF
New Contributor III
Hi and thanks for your reply.
I will prepare a test application to show my tries as soon as possible and I will submit it to your attention.
Best regards.
PaoloF
New Contributor III
at this time I changed frontend code using ES modules and now map is loading again.
So I think this issue could be considered solved.
Now I have another probleam that I will describe in different thread.
Really appreciate your help support.
