API Composite geocode service
1037
05-20-2021 05:37 AM
ColinGowens
I have a search widget that will gecode to our enterprise service with a standard us streets service, but it fails to return a result when using a composite service built from points and lines.  In the us streets version, I set this variable singleLineFieldName: "Single Line Input", and it works to return a point.  For the composite it is set up with singleLineFieldName: "SingleLine", and this fails to return a result.  The service does work outside of the api page.  Can the api work with a composite service?
here is the code that fails
includeDefaultSources: false,
sources: [
name: "Composite Address",
placeholder: "example: address",
locator: new Locator({
url: "https://url.com/CompositeGeocode/GeocodeServer"
Noah-Sager
Hi @ColinGowens, the API should work fine with a composite geocoder. Here is an example app:
https://codepen.io/noash/pen/qBrRrPa?editors=1000
My hunch is that the issue is related to the composite geocoder itself. I found this thread with some tips about publishing a composite geocoder from Pro that might be useful: https://community.esri.com/t5/arcgis-online-questions/composite-address-locator/m-p/732528
If you want to share the URL to the geocoder you are using (if it's public), I can test with it as well.
