Any examples of Print widget with Print Task?
898
02-22-2019 12:21 PM
XavierLinus
Hello All,
I am new to coding in general and trying to get print task to work with the print widget button.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Print widget - 4.10</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.10/esri/css/main.css">
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
</style>
<script src="https://js.arcgis.com/4.10/"></script>
<script>
require([
"esri/views/MapView",
"esri/widgets/Print",
"esri/WebMap",
"esri/tasks/PrintTask",
"esri/tasks/support/PrintTemplate",
"esri/tasks/support/PrintParameters"
function(
MapView, Print, WebMap, PrintTask, PrintTemplate, PrintParameters
var webmap = new WebMap({
portalItem: { // autocasts as new PortalItem()
var view = new MapView({
container: "viewDiv",
map: webmap
view.when(function(){
var print = new Print({
view: view,
// specify your own print service
var printTask = new PrintTask({
url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"
view.ui.add(print, "top-right");
var template = new PrintTemplate({
format: "jpg",
exportOptions: {
dpi: 300
layout: "a4-landscape",
layoutOptions: {
titleText: "Test",
authorText: "Carson",
forceFeatureAttributes: true,
showLabels: true,
Preservescale: true,
var params = new PrintParameters({
view: view,
template: template
const printResult = result => window.open(result.url, "_blank")
const printError = error => console.log(error)
printTask.execute(params).then(printResult, printError);
</script>
</head>
<body class="calcite">
<div id="viewDiv"></div>
</body>
</html>
Im unsure how to "combine" the two. Thank you.
RobertScheitlin__GISP
Xavier,
   The print widget is a wrapper that handles the PrintTask and PrintTemplates for you. You would never combine the two in an app it is one or the other. Why are you thinking that you need to combine them?
