Add Field Programmatically with JavaScript API
470
06-12-2019 04:41 PM
ChrisSeabrooke1
New Contributor III
Is it possible to add a field to an existing feature layer through the JavaScript API? I know how to create a new feature layer and define the fields in it. I'm wondering if it's possible to modify the feature layer's schema through the API.
RobertScheitlin__GISP
Chris,
   No you can not make schema changes to a layer in a map service using the JS API.
