Add attachment with javascript api 4.x
2235
08-02-2018 07:53 PM
JamesMoloney2
New Contributor II
Hi all
I have a feature layer that has attachments.
Using the javascript api I can query the feature layer for attachments using the queryFeatureAttachments method
eg
fl.queryFeatureAttachments(feature).then(function(attachments){
 for (var x = 0, xl = info.length; x < xl; x++) {
   console.log(attachments[x]);
So I now have the attachments and I can log them to console.
My question is how do I attach these attachments to a feature in another feature service?
There is no method in the javascript api 4.x to add an attachment
Has anyone worked out a way to do this? I was thinking of using the rest api Add Attachment—ArcGIS REST API: Services Directory | ArcGIS for Developers but I'm not sure what the post object should look like?
Any help here would be much appreciated
Thanks
James
RobertScheitlin__GISP
James,
   This thread is from 3.x API but it is using the REST service to add the attachement so I should work in 4.x:
https://community.esri.com/thread/107648
JamesMoloney2
New Contributor II
Hi Robert,
Thanks for pointing me to the post above...
This is what I have so far,
                    console.log(attachments);
                         for (var x = 0, xl = attachments.length; x < xl; x++) {
                                var contentType = attachments[x].contentType;
                                var contentName = attachments[x].name;
                                var xhr = new XMLHttpRequest();
                                xhr.open("GET",attachments[x].url,true);
                                xhr.responseType = "arraybuffer";
                                xhr.onload = function(evt){
                                     console.log(this.response);
                                   var arrayBufferView = new Uint8Array( this.response );
                                   var blob = new Blob([ arrayBufferView ], { type: contentType });
                                   var formData = new FormData();
                                   formData.append("method", "post")
                                   formData.append("enctype", "multipart/form-data");
                                   formData.append("attachment", blob, contentName);
                                   console.log(formData);
                                    esriRequest({
                                      url: "https://services8.arcgis.com/[AGO]/arcgis/rest/services/[fl]/FeatureServer/0/[objectid]/addAttachmen...",
                                      form: formData,
                                      content: {
                                          f: "json"},
                                      handleAs: "json"
                             }).then(function (response){
                                 console.log(response);
                                xhr.send(contentType,contentName);
but I am getting this error
dojo.js:412 Uncaught TypeError: d.slice is not a function
at Object.G [as isBlobProtocol] (dojo.js:412)
at dojo.js:452
at XMLHttpRequest.xhr.onload (gch.js:331)
Any ideas what this means?
Thanks James
James,
  Sorry I do not.  Maybe Rene Rubalcava‌ can help.
JohnGrayson
I would just use esriRequest instead of XMLHttpRequest, and also please note that the signature for esriRequest is different at 4.x so it won't work as you have it above: Esri Request | API Reference
SamHall
New Contributor II
I am getting the same error. Any update on this original issue?
