Hi all
I have a feature layer that has attachments.
Using the javascript api I can query the feature layer for attachments using the queryFeatureAttachments method
eg
fl.queryFeatureAttachments(feature).then(function(attachments){
for (var x = 0, xl = info.length; x < xl; x++) {
console.log(attachments[x]);
So I now have the attachments and I can log them to console.
My question is how do I attach these attachments to a feature in another feature service?
There is no method in the javascript api 4.x to add an attachment
Has anyone worked out a way to do this? I was thinking of using the rest api Add Attachment—ArcGIS REST API: Services Directory | ArcGIS for Developers but I'm not sure what the post object should look like?
Any help here would be much appreciated
James
James,
This thread is from 3.x API but it is using the REST service to add the attachement so I should work in 4.x:
Hi Robert,
Thanks for pointing me to the post above...
This is what I have so far,
console.log(attachments);
for (var x = 0, xl = attachments.length; x < xl; x++) {
var contentType = attachments[x].contentType;
var contentName = attachments[x].name;
var xhr = new XMLHttpRequest();
xhr.open("GET",attachments[x].url,true);
xhr.responseType = "arraybuffer";
xhr.onload = function(evt){
console.log(this.response);
var arrayBufferView = new Uint8Array( this.response );
var blob = new Blob([ arrayBufferView ], { type: contentType });
var formData = new FormData();
formData.append("method", "post")
formData.append("enctype", "multipart/form-data");
formData.append("attachment", blob, contentName);
console.log(formData);
esriRequest({
url: "https://services8.arcgis.com/[AGO]/arcgis/rest/services/[fl]/FeatureServer/0/[objectid]/addAttachmen...",
form: formData,
content: {
f: "json"},
handleAs: "json"
}).then(function (response){
console.log(response);
xhr.send(contentType,contentName);
but I am getting this error
dojo.js:412 Uncaught TypeError: d.slice is not a function
at Object.G [as isBlobProtocol] (dojo.js:412)
at dojo.js:452
at XMLHttpRequest.xhr.onload (gch.js:331)
Any ideas what this means?
Thanks James
James,
Sorry I do not. Maybe Rene Rubalcava can help.
I would just use esriRequest instead of XMLHttpRequest, and also please note that the signature for esriRequest is different at 4.x so it won't work as you have it above: Esri Request | API Reference
I am getting the same error. Any update on this original issue?
