4.x Sketch widget in a side panel?
620
07-18-2019 04:27 PM
SteveCole
3.x to 4.x migration pains- Can you place the sketch widget in a div located outside of the map? I'm developing an app which uses an AccordionPane to define a workflow and one step is to draw a graphic and I'd like to place the widget in one of the AccordionPanes. The Sketch widget sample uses "view.ui.add()" to place the sketch widget into the map but I don't see another way to specify where the widget is placed.
Thanks!
Steve
KenBuja
Use the container property to put it into a div
const sketch = new Sketch({
  layer: layer,
  view: view,
  container: document.getElementById("myDiv")
KenBuja
  layer: layer,
  view: view,
SteveCole
Perfect! Thanks Ken.
