4.11 Can't Edit layer
482
03-28-2019 09:09 PM
JeremyLuymes
New Contributor III
Any suggestions on why I can't edit a layer in 4.11?
I used the basic code in the Editor widget sample, swapping out a layer from a published service. Below are the settings on ArcGIS server, seems like they should allow for editing. The map and layer loads but the editor widget does not display. Any idea why the Editor widget isn't showing up?
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Edit test</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.11/esri/css/main.css">
  <link rel="stylesheet" href="css/mapstyle.css">
  <script src="https://js.arcgis.com/4.11/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/layers/FeatureLayer",
      "esri/widgets/Editor",
      "esri/widgets/Search",
      "esri/widgets/Home",
    ], function(Map, MapView, FeatureLayer,Editor,Search,Home) {
      var map = new Map({
        basemap: "gray-vector"
      var view = new MapView({
        container: "viewDiv",
        map: map,
        center: [-78.491,38.036],
        zoom: 12,
        padding:{
          top:30
      var poleLyr = new FeatureLayer({
        url: "SERVERURL/CVPoles/MapServer/0",
        title: "Poles",
        visible: true
      map.add(poleLyr)
      var editor = new Editor({
        view: view
      view.ui.add(editor,"top-left");
      var home = new Home({
        view: view
      view.ui.add(home,"top-left");
      //add search
      var search = new Search({
        view: view,
        locationEnabled: false,
        maxSuggestions: 4,
        popupOpenOnSelect: false,
        container: "searchDiv"
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <div id="editorDiv"></div>
  <div id="searchDiv"></div>
</body>
</html>
RobertScheitlin__GISP
Jeremy,
   The url has to be FeatureServer Not MapServer:
        url: "SERVERURL/CVPoles/FeatureServer/0",
        title: "Poles",
        visible: true
Jeremy,
        title: "Poles",
        visible: true
JeremyLuymes
New Contributor III
Thanks so much Robert, can't believe I didn't notice that! Everything is working now, appreciate the help.
