To add a feature layer on map with ES Modules
2505
05-23-2021 10:48 PM
Valgenmap
New Contributor III
I wanted to build an example app using ReactJS and JS API 4.x  with ES Modules.
I followed few examples provided by ESRI as below,
1. https://github.com/odoe/jsapi-react-template
2. https://github.com/Esri/nearby-javascript
3. https://github.com/odoe/esrijs4-vm-react
4. https://github.com/Esri/react-arcgis
But I'm not able to get it, coz each one is following different approaches.
Even I tried by requesting a case with ESRI technical team, but I didn't received a proper solution.
So, can I get any exmaple source so that I can get clear knowledge How to add the Map and a FeatureLayer with ES Modules using React core and Reacthooks.
Regards,
Valgen Map
JuliePowell
Hello @Valgenmap ! Have you seen this sample? It is the best and most recent one for working with the API's ES modules & React.
ESM samples / jsapi-create-react-app
Julie
Valgenmap
New Contributor III
Hi @JuliePowell ,
Yes, I had gone through with the sample provided by ESRI. But in that sample they are adding the map and layer through the portal id, so I didn't mention that in my first comment.
I need help to get  an idea in How to add the Map and  FeatureLayer with ES Modules using React core and Reacthooks.
Regards,
ValgenMap
RichardMoussopo
Occasional Contributor III
Hi Valgenmap, this should be a question to the ArcGIS API for JavaScript Community
https://community.esri.com/t5/arcgis-api-for-javascript/ct-p/arcgis-api-for-javascript
But you can achieve this by using esri-loader module
import { loadModules } from 'esri-loader';
const initMap = () => {
      loadModules([
        "esri/Map",
        "esri/views/MapView"
        .then(([Map, MapView]) => {
          const map = new Map({
            basemap: 'streets-night-vector',
          const view = new MapView({
            container: "viewDiv",
            map,
            center: [-82.515401, 40.771119],
            zoom: 10,
