ArcGIS API for JavaScript - Introduction:
Map your outdoor activities in 3D with the elevation profile widget
Building dynamic web applications with the ArcGIS API for JavaScript
Wildfires & smoke forecast app (using blend & layer effects)
(here is the official API sample which is a little simpler)
The rest of the apps were samples that can be found in the online documentation. Here are some resources you might find useful:
•ArcGIS API for JavaScript Documentation
•FeatureLayer clustering sample
•GeoJSON client-side projection sample
•Using widgets with React sample
Demos can be found here:
https://github.com/odoe/jsapi-uc2021-demo
