Wind Rose on Map
2164
01-14-2012 10:45 PM
shafitrumboo
I have point location on map now i need to draw wind rose on map on the points. I have the data for wind rose. Is it possible to create symbol like this
RussellEgypt
Hi
Just wanted to find out if you received a solution for your question?
Regards
ThomasMcCracken
Try using a <esri:PictureMarkerSymbol> with your image as the source.  Good luck.  Please check this as the answer if it helps, thanks.
Thomas McCracken
GIS Analyst
Georgia Power Company
