Where is PopUpRendererSkin.mxml in 3.1
2009
6
04-09-2013 12:55 PM
AndreaGrygo
Was the PopUpRendererSkin.mxml replaced in 3.1?
I'm looking for it to change the size of the PopUp window.
Thank you.
YannCabon
It wasn't replaced in 3.1.
It's under the skin folder: skins\src\com\esri\ags\skins
AndreaGrygo
YannCabon
Ho,
The PopUpRendererSkin is in the skins folder of the API, not the viewer.
RhettZufelt
MVP Notable Contributor
TomSchuller
Hy,
the skin is inlucded in the API, not in the viewer.
Just download the ArcGIS Flex API (arcgis_api_for_flex_3_2.zip)
  http://links.esri.com/flex-api/latest-download
and take a look in the folder:
ArcGIS_Flex\skins\src\com\esri\ags\skins
Tom
AndreaGrygo
Thanks all for your help, I found it and was able to successfully add it to the viewer:
Added to viewer under src > com.esri.viewer > skins > supportClasses
Added the following to defaults.css so the viewer would use the file:
esri|PopUpRenderer
 skin-class: ClassReference("com.esri.viewer.skins.supportClasses.PopUpRendererSkin");
