Silvia, no.If I disable my network device i recieve this error message: [RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: http://www.arcgis.com/sharing/content/items/78e9ed6c172a43719e2114cfb7f6d306?f=json"]. URL: http://www.arcgis.com/sharing/content/items/78e9ed6c172a43719e2114cfb7f6d306?f=json"]
at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::faultHandler()
at mx.rpc::Responder/fault()
at mx.rpc::AsyncRequest/fault()
at DirectHTTPMessageResponder/errorHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.net::URLLoader/onComplete()
You need to search in adobe forums about: "event listeners", "event dispatchers". cannot convert mx.rpc.events::FaultEvent@13a5a301 to com.esri.ags.events.LayerEvent
just fill the difference:wrong code:var wmUtil:WebMapUtil = new WebMapUtil();
wmUtil.addEventListener(FaultEvent.FAULT, onWebMapUtilFault, false, 0, true);
protected function onWebMapUtilFault(event:LayerEvent):void // wrong event type
TypeError: Error #1034: Type Coercion failed: cannot convert mx.rpc.events::FaultEvent@ad35f81 to com.esri.ags.events.LayerEvent.
working code:var wmUtil:WebMapUtil = new WebMapUtil();
protected function onWebMapUtilFault(event:FaultEvent):void
trace(event.fault.getStackTrace());
Sample:<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx"
xmlns:ags="http://www.esri.com/2008/ags">
<!-- Adobe Flex SDK 4.5.1 -->
<!-- ArcGIS API for Flex 2.5 -->
<!-- http://web.zone.ee/bespiva/webmaputil/ -->
<s:layout>
<s:HorizontalLayout gap="5"
paddingBottom="10"
paddingLeft="10"
paddingRight="10"
paddingTop="10" />
</s:layout>
<fx:Script>
<![CDATA[
import com.esri.ags.Map;
import com.esri.ags.events.WebMapEvent;
import com.esri.ags.webmap.WebMapUtil;
import mx.controls.Alert;
import mx.events.FlexEvent;
import mx.rpc.AsyncResponder;
import mx.rpc.Fault;
protected function onPanelCreationComplete(event:FlexEvent):void
var targetPanel:Panel = event.target as Panel;
switch (targetPanel.id)
case (panel1.id):
wmUtil.createMapById("69f7b98f49db4becb44ac2de3aa37dd9",
new AsyncResponder(onCreateMapByIdComplete, onFault, targetPanel.id));
break;
case (panel2.id):
wmUtil.createMapById("f3b0db715d9148f7a4d3b4f8159b90b5",
break;
case (panel3.id):
wmUtil.createMapById("b3b981c496d443749fdc8661f9e38e65",
break;
case (panel4.id):
wmUtil.createMapById("78e9ed6c172a43719e2114cfb7f6d306",
break;
protected function onCreateMapByIdComplete(event:WebMapEvent, token:Object = null):void
if (event.errors.length > 0)
for (var i:int; i < event.errors.length; i++)
trace(event.errors);
return;
var map:Map = event.map as Map;
if (map != null)
switch (token.toString())
case panel1.id:
panel1.removeAllElements();
panel1.addElement(map);
break;
case panel2.id:
panel2.removeAllElements();
panel2.addElement(map);
break;
case panel3.id:
panel3.removeAllElements();
panel3.addElement(map);
break;
case panel4.id:
panel4.removeAllElements();
panel4.addElement(map);
break;
protected function onFault(fault:Fault, token:Object = null):void
trace(fault.getStackTrace());
Alert.show(fault.message.toString(), "Fault");
</fx:Script>
<s:VGroup gap="5"
width="100%"
height="100%">
<s:Panel id="panel1"
title="Top-Left panel"
width="100%"
height="100%"
creationComplete="onPanelCreationComplete(event)">
</s:Panel>
<s:Panel id="panel2"
title="Bottom-Left panel"
width="100%"
height="100%"
</s:Panel>
</s:VGroup>
<s:VGroup gap="5"
width="100%"
height="100%">
<s:Panel id="panel3"
title="Top-Right panel"
width="100%"
height="100%"
</s:Panel>
<s:Panel id="panel4"
title="Bottom-Right panel"
width="100%"
height="100%"
</s:Panel>
</s:VGroup>
</s:Application>
