Using ownership-based access control.
4300
07-17-2014 05:00 PM
MiguelMartinez1
New Contributor II
I'm, trying to implement ownership-based access control, I confirudes my Feature server and it works perfect from rest directory(Login form appears correctly).
When I try to access to my FeatureServer (secured) from rest directory(".../arcgis/rest/services/Edit/Editing/FeatureServer/0") from Web Browser I had to use my User/password, this is fine and works great, when I execute submit from rest using user/password I CAN see password value encrypted and then I can view my FeatureServer.
My problem, I'm trying to use an example using Flex (Edit secure service—ArcGIS API for Flex | ArcGIS for Developers) using my FeatureServer(secured),
I have customized my login window using
IdentityManager.instance.signInWindowClass= mySkins.supportClasses.customSignInWindow;
IdentityManager.instance.enabled = true;
My problem is that I can NOT ENCRYPT PASSWORD value(it's visible when post executes), I thought that was just my code, I saw original
example and it works on the same way(PASSWORD is visible without encryption).
Any ideas? How can I encrypt password in Flex app just like when I access from Web Browser using my url:
".../arcgis/rest/services/Edit/Editing/FeatureServer/0"?
Thanks!!
DasaPaddock
It's recommended to enable SSL to secure the traffic from your Flex application to your server.
See:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
DasaPaddock
Where is it visible? Are you using HTTPS?
MiguelMartinez1
New Contributor II
Hi Dasa Paddock,
It's visible on rest directory from web browser(not using HTTPS) at:
http://MyServer:6080/arcgis/rest/services/Edit/Editing/FeatureServer/0
when I navigate to URL page asks for user/password, when I click Login button password value is encrypted
Thanks!
DasaPaddock
See:
MiguelMartinez1
New Contributor II
Ok,
Reading the link...and I'll try.
Thank you!
