Hello everybody,
I have 2 layers in the map (1 polyline layer and 1 polygon layer), and a "select and zoom" function which will select a feature and zoom to it.
The strange thing is although I use the same code(except the geometry type), the result is different:
- for polygon feature : can select the feature and zoom to it properly.
- for polyline feature : only zoom to the feature, but never select the feature.
I cannot figure out why this happen, is this because of the layer data or something else?
The code I am using is as follows:
private function onSelectItem(e:ContextMenuEvent):void{
if(datagrid.selectedIndex >= 0){
this.cursorManager.setBusyCursor();
if (datagrid.selectedItem.shape == "Polyline")
var query:Query = new Query;
queryTask.url = "http://localhost:6080/arcgis/rest/services/MyService/MapServer/0";
query.where = "Segment_ID = '" + datagrid.selectedItem.segmentID + "'";
query.outSpatialReference = map.spatialReference;
query.returnGeometry=true;
queryTask.execute(query, new AsyncResponder(onResult, onFault));
else if (datagrid.selectedItem.shape == "Polygon")
var queryP:Query = new Query;
queryTask.url = "http://localhost:6080/arcgis/rest/services/MyService/MapServer/1";
queryP.where = "Segment_ID = '" + datagrid.selectedItem.segmentID + "'";
queryP.outSpatialReference = map.spatialReference;
queryP.returnGeometry=true;
queryTask.execute(queryP, new AsyncResponder(onResultPolygon, onFault));
function onResult(featureSet:FeatureSet, token:Object = null):void
graphicsLayer.clear();
if (featureSet.features.length == 0)
Alert.show("No feature found. Please try again.");
else
var unionExtent:Extent;
var myFirstGraphic:Graphic = featureSet.features[0];
unionExtent = Polyline(myFirstGraphic.geometry).extent;
myFirstGraphic = new Graphic();
for each (var myGraphic1:Graphic in featureSet.features)
myFirstGraphic.geometry = myGraphic1.geometry;
graphicsLayer.add(myGraphic1);
if(myGraphic1.geometry !== myFirstGraphic.geometry){
unionExtent = unionExtent.union(Polyline(myGraphic1.geometry).extent);
map.extent = unionExtent;
function onResultPolygon(featureSet:FeatureSet, token:Object = null):void
else
unionExtent = Polygon(myFirstGraphic.geometry).extent;
unionExtent = unionExtent.union(Polygon(myGraphic1.geometry).extent);
function onFault(info:Object, token:Object = null):void
Alert.show(info.toString());
I am using ArcGIS api for flex 3.6, thanks in advance.
