QueryTask,AsyncResponder - error converting from 1.3 to 2.0
2855
08-30-2010 01:05 PM
CarmenDurham
I am trying to convert a NON-SFV Flex app from 1.3 to 2.0 using FlashB4 and SDK4.
I finally got everything to compile and the application will start, but the "queryTask" line of code goes straight to onFault (worked fine before conversion).  There is a valid value in txtAddress.text at time query is submitted:
query.where = "[ADDRESS] ='" + txtAddress.text + "'";
queryTask.execute(query, new AsyncResponder(onResult, onFault));
Fault Alert error:
[RPC Fault faultString="Error #2032" faultCode="null" faultDetail="null"]
Any ideas?  I am importing com.esri.ags.FeatureSet.
Carmen
RobertScheitlin__GISP
Carmen,
   If you are querying a 9.3 server and not a 10 server than ensure you set useAMF = false; on the queryTask.
CarmenDurham
Thanks Robert.  I had indeed forgotten to go back and read the "Still connecting to a 9.3 ArcGIS Server" item in the "Migrating from 1.3 to 2.0" document at:
http://help.arcgis.com/en/webapi/flex/help/index.html#migrating.htm#
Works now!
Carmen
