querying related tables
5945
17
01-31-2012 11:14 AM
eddiequinlan
Hopefully someone has a simple answer which eludes me.
I've read the documentation on feature layers, the queryRelatedFeatures, and various coding examples.  The concept/coding doesn't appear to be very difficult, however, I'm doing something wrong.
I'm trying to query a feature layer (parcel layer) and from there query the related table (sales table).   The user draws a graphic on the map, and from there the results are returned.  The feature layer is querying correctly.  It then queries the related table and this is where the problem begins.  The query relate does not fail; it's only returning the records (sales) from the first parcel number in the parcel layer (queried layer).  I've tried all kinds of coding variations and can't get past this point.  HELP!
sincerely,
Eddie
Here is the code.
[PHP]
private function SearchLayer(event:DrawEvent):void
sQuery = new Query();
sQuery.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
//sQuery.where = exp_use;  //search by use code
sQuery.geometry = event.graphic.geometry;  //search with geometry
my_layer.addEventListener(FeatureLayerEvent.SELECTION_COMPLETE, onComplete_FeatureLayerSelection);
//my_layer.useAMF = true;
my_layer.selectionColor = 0x08f36b;
my_layer.outFields = ["*"];
my_layer.selectFeatures(sQuery, FeatureLayer.SELECTION_NEW);  // search feature layer.......
private function onComplete_FeatureLayerSelection(e:FeatureLayerEvent):void
relatedQuery.objectIds = [e.features[0].attributes.FID];  //FID number in featurelayer
if (e.features.length > 0)
  my_layer.queryRelatedFeatures(relatedQuery, new AsyncResponder(onResult, onFault));
  function onResult(relatedRecords:Object, token:Object = null):void
   var fset:FeatureSet = (relatedRecords[e.features[0].attributes.FID]);
   var objIds:Array = new Array();
   for each (var g:com.esri.ags.Graphic in fset.features)
    objIds.push(g.attributes.SAPRICE);
    trace(g.attributes.SAPRICE);
   trace(objIds);
  function onFault(info:Object, token:Object = null):void
   trace("on fault issue");
else
  Alert.show("No Records Found");
[/PHP]
eddiequinlan
Hi Robert,
Thank you so much for your time and effort.  I copied the code you supplied and tried it out.  I get the same results as before.  After looking at the code, it's essentially what I already have.  It keeps returning the first (or maybe the last) queried record from the featurelayer and then returning the associated related records from the relate table.  I'm at a loss.  I already wrote some code to loop thru featurelayer records and query each of those against the relate table.  That seems to work fairly well.  I'm tying up some loose ends on it and checking the results.  I sure wish I/you could figure out why I'm not getting the queryrelate feature to work correctly.  If it's of any value to anyone, I'll post my code when I'm finished.  Robert, if you have anymore ideas please let me know.
Thanx again,
Eddie
RobertScheitlin__GISP
Eddie,
  So now I understand what you are looking for.
Try this then
                var oidArr:Array = [];
                for (var rf:int=0; rf < e.features.length; rf++){
                    oidArr.push(e.features[rf].attributes.OBJECTID);
                relatedQuery.objectIds = oidArr;
                trace(oidArr); // shows array of numbers
                //relatedQuery.objectIds = [e.features[0].attributes.OBJECTID];  //FID number in featurelayer
                if (e.features.length > 0){
                        for (var rr:int = 0; rr < e.features.length; rr++){
                            var fset:FeatureSet = (relatedRecords[e.features[rr].attributes.OBJECTID]);
                            if(fset){
                                    objIds.push(g.attributes.Local_ID);
                                    trace(g.attributes.Local_ID);
                                trace(objIds);
                else{
eddiequinlan
Hi Robert,
That did it!!!  The problem was this part of the loop......
oidArr.push(e.features[rf].attributes.FID);
I know I had tried some variation of this, but I think I accidentally was setting the relatedQuery.objectIds inside the loop... doh!  Anyway, it's good to have the forum and people like yourself to review simple issues such as this one.  Thank you again.
If anyone is interested, since I have both methods working; it appears that the speed of returning the records is about the same.  However, the relatedQuery method code is shorter, standardized, and easier to follow.  Also, my two loops bail-out occassionally.  I haven't figured out why.  It seems to happen when the spatial select on the feature layer is fairly large.  At this point, I haven't been able to replicate the failure.
Thanx Robert.
Sincerely,
Eddie
Eddie,
   Glad you got it working. Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
eddiequinlan
never really paid attention to what those icons on the right were for..............
eddiequinlan
I have another question for anyone.......
Once the query relate has returned the records from the query related table, is there an efficient way to shade only those records on the map?
If I only use the queryrelatedfeatures it shades all the initial records from the featurelayer.  I've taken/created an array from the returned records and then Query() each one of those records to "shade" the map.  However, this looping is time consuming and not efficient.
Sincerely,
Eddie
Eddie,
   So are you wanting to combine all the OIDs into one query? If so then all you do is this SQL Statement in the querys where attribute:
OBJECTID IN (1,2,3,4,5,6,7,8,9,10)
eddiequinlan
Hi Robert,
Yea thats what I did, but then my sql query looks something like:
where attribute = 1 or attribute = 3 or attribute = 100 etc.....  I may end up with a 1000 or's
The other option I've done is to query each record in a loop.  Either way, they are both slow when I get more than a 100 records.  The speed between the two seems to be about the same.
Robert thanx for responding,
Eddie
