Printing tables to pdf along with map
3015
19
10-03-2013 08:45 PM
IrisGreen
Hello Everyone,
I need to print tables generated using a query along with the Map in "pdf" format such that they are auto arranged in the white
space on the map.
I am looking for any suggestion using flex which can help me do this.
Thanks in Advance.
Iris
MGSethe
New Contributor II
I ran a quick test and it is possible using alivePDF, just add your legend as a component to the map and you can use the addimage property in alivePDf to add the legend as an image to the report.
Hello Aaron
Thanks for the quick reply, I tried it and I am not winning, could you please share the code you have if you do not mind?
I am referring to the code that have the Legend.
Thanking you in advance
AaronNash1
Occasional Contributor II
attached is a text file of the project I was working on, its a simple PDF report. just shows that it can be done.
MGSethe
New Contributor II
Thanks a million times. It did the trick
LefterisKoumis
Occasional Contributor III
oops didn't see this until just now. sorry no, its the clients. but if you have specific questions i can probably whip up generic cf code.
Thank you Paul.  I am interested to see how you posted the legend. Any generic code to share, I'd appreciate it. Thanks.
PaulHastings1
our suite of apps parses the layers in each map service the apps will use via rest calls (an admin app that sets which users/groups can use which map services/tools, etc). that includes the legends. that's all stored in a sql server table & this reporting tool simply pulls that data out of the table & adds it to the PDF.
the map template is from arcMap. i get a PDF of that blank template & measure out the available space for the legend, etc. using a PDF tool (foxit for example)--mainly because the designers either don't know or won't say the space available for each piece of the template. those become constants. the legend,etc. tables are built in server memory & measured against the available space.if they fit, they go in, if not they get added to a supplemental page (next iteration will measure rows & fit as many as possible instead of this binary approach).
if you can read coldfusion, i'll try to get a generic example together.
LefterisKoumis
Thank you for your reply, Paul. It it very interesting the approach you described and open up to me new possibilities. I have a license of CF 9, and I was using it for web apps but since then I turned my attention to ASP.NET. Based on your reply, it seems that you also have a license for the Foxit PDF SDK to implement in your solution.  If you provide a generic example it will be very helpful. Thanks.
PaulHastings1
no, as i said, we're using coldfusion & the iText version that comes w/it, server side. foxit that i used to measure the template bits is the free version. nothing special about it.
LefterisKoumis
attached is the code I used in my application. Any questions let me know
Aaron, thank you for posting the code for printing the display features in a pdf.
For the report.pdf, I assume that you used a spark datagrid. Could you please post the code for printing to pdf the datagrid as displayed in the report.pdf? Thanks.
AaronNash1
here is some code for just printing a table
public function generatePDF2():void
     var myCoreFont1:IFont = new CoreFont ( FontFamily.ARIAL );
     myPDF = new PDF(Orientation.PORTRAIT, Unit.MM, Size.TABLOID);
     myPDF.setDisplayMode( Display.FULL_PAGE, Layout.SINGLE_PAGE );
     myPDF.addPage();
     myPDF.setFont(myCoreFont1, 12);
     myPDF.addText('List of Development Services Projects - Status', 11, 10);
     myPDF.setFont(myCoreFont1, 8);
     myPDF.addText('Printed:' + dateFormatter.format(now.toLocaleDateString()), 180, 10);
     var gridColumnOwner1:GridColumn = new GridColumn("Project Name", "Name", 90, Align.LEFT, Align.LEFT);
     var gridColumnOwner2:GridColumn = new GridColumn("Condition", "Color", 18, Align.LEFT, Align.LEFT);
     var gridColumnAddress:GridColumn = new GridColumn("Status", "Status", 20, Align.LEFT, Align.LEFT);
     var gridColumnMailCity:GridColumn = new GridColumn("Next Step", "Cur_Status", 20, Align.LEFT, Align.LEFT);
     var gridColumnMailStat:GridColumn = new GridColumn("Department", "DS_Department", 35, Align.LEFT, Align.LEFT);
     var gridColumnManager:GridColumn = new GridColumn("Project Manager", "Manager", 35, Align.LEFT, Align.LEFT);
     var gridColumnCost:GridColumn = new GridColumn("Project Assistant", "Assistant", 35, Align.LEFT, Align.LEFT);
     myPDF.textStyle ( new RGBColor ( 0x000000 ), 1 );
                                        //resultsGrid is the name of the datagrid
     var grid:Grid = new Grid (resultsGrid.dataProvider.toArray(), 0, 0, new RGBColor (0xC0C0C0),
      new RGBColor (0xCCCCCC), true , new RGBColor(0x000000), 1, Joint.ROUND);
     var columns:Array = new Array (gridColumnOwner1,gridColumnOwner2, gridColumnAddress, gridColumnMailCity, gridColumnMailStat, gridColumnManager, gridColumnCost);
     grid.columns = columns;
     myPDF.addGrid(grid, 1, 6);
     //export to pdf web service
     myPDF.save(Method.REMOTE, "name of server",Download.INLINE,"myPDF.pdf");
LefterisKoumis
     myPDF.addPage();
Thank you.  I got a bit of work to do. The layers and the attributes are pre-selected by the user before the datagrids are printed out.
