I,AM BEGINNER IN FELX API USING ARCGIS SERVER 9.3.1
2675
11
06-04-2010 12:11 AM
mohamedabouzaid
HELLO ALL ,
ITS MY FIRST WEB APP USING FLEX API
WOULD ANY ONE PLEASE TO GIVE ME THE CODE FOR PUTTING MY OWN DATA LIKE SHAPEFILES_GEODATABASE
IN MY APPLICATION.
THANKS ALOT .
Drew
Mohamed,
Even before you start your flex application I would verify that your service is started and works.
You can do this by navigating to the REST services folder in your browser and selecting your newly created service.
From the above threads it looks like the URL to your REST services would be:
http://orcl/ArcGIS/rest/services/
If your rest service is NOT listed, you may have to clear your REST Cache. The URL to your REST admin would probably be:
http://orcl/ArcGIS/rest/admin (Use your AGS user to login)
One you have verified your service is created and is listed as a REST Service, click it then verify it works by clicking the " View In - ArcGIS JavaScript" link.
Once you have verified the REST service is up and going, then read the documents linked by Robert.
After all that I would suggest  working with the Flex code samples that have been listed on this thread.
Drew
mohamedabouzaid
thanks a lot for all.
i think i can try the sample code and read some documentations about flex to get the right result
regards
