How to know which layers are currently visible
1101
04-25-2014 10:52 AM
EzequiasRodrigues_da_Rocha
Hi
I am wondering if it is possible to retrieve the current information of visible layers.
I have found many samples but all relating to what is defined on the map service.
My idea is to retrieve with layers are checked as visible at a certain moment in the application.
I tried lately to add a event listener but I didn't have any success.
AppEvent.addListener(AppEvent.MAP_LAYER_VISIBLE, mapLayerVisibleHandler);
Regards
Ezequias Rocha
Solution
private var _displayLayers:ArrayCollection = new ArrayCollection();
private function loadConfig():void{
_displayLayers.removeAll();
_displayLayers.addAll(getVisibleLayers());
private function getVisibleLayers():ArrayCollection
   var layers:ArrayCollection = new ArrayCollection();
   var mapServices:Array = getServices();
   var tempLayer:Object;
  for each(var mapService:ArcGISDynamicMapServiceLayer in mapServices)
   if (mapService is ArcGISDynamicMapServiceLayer)
    if (mapService && mapService.visible)
     if (mapService.visibleLayers)
      for(var i:int = 0; i < mapService.visibleLayers.length; i++)
      {              tempLayer = new Object();
       tempLayer.index = mapService.visibleLayers.getItemAt(i);
       tempLayer.service = mapService.id;
       tempLayer.url = mapService.url;
       tempLayer.layer = mapService.name;
       layers.addItem(tempLayer);
  return layers;
Solution
  return layers;
