How to Get JSON Representation of Map?
2818
12-18-2012 01:36 PM
AlejandroVargas
I believe my question has a simple answer.  I just don't know how to do this yet.
Using ArcGIS API for Flex 3.0, how does one get the JSON representation of a Map.  I'm looking for a function like map.asJSON() or something like that.
Is it as simple as a
JSONUtil.encode(map);
call?
Thanks!
EstherColero
Hello Alejandro,
I'm not sure if there is some function in the API to convert directly the map to JSON, but you can do the trick with the class PrintParameters
var pPrintParameters:PrintParameters = null;
var jsonMap:Object = null;
var strJsonMap:String = "";
pPrintParameters = new PrintParameters();
pPrintParameters.map = map;
jsonMap = pPrintParameters.toJSON().Web_Map_as_JSON;
strJsonMap= ObjectUtil.toString(jsonMap);
Hope this helps 🙂
Best regards
Esther
AlejandroVargas
That's great, Esther.  Thanks for your reply!
Does the PrintParameters yield JSON that conforms to ESRI's ExportWebMap Specification?
http://resources.arcgis.com/en/help/main/10.1/index.html#//0154000004w8000000
EstherColero
Hello Alejandro,
I'm not sure, but print widget is supposed to use that specification to call the geoprocess, so should not be any difference.
Regards
Esther
