<?xml version="1.0" ?> <!-- //////////////////////////////////////////////////////////////////////////////// // // Copyright (c) 2010 ESRI // // All rights reserved under the copyright laws of the United States. // You may freely redistribute and use this software, with or // without modification, provided you include the original copyright // and use restrictions. See use restrictions in the file: // <install location>/License.txt // //////////////////////////////////////////////////////////////////////////////// --> <configuration> <httpproxy enabled="false">proxy.php</httpproxy> <title>Frederick County General Mapping</title> <subtitle></subtitle> <logo>assets/images/fredc-assembled.png</logo> <stylesheet>blackgold.swf</stylesheet> <!-- UI elements --> <widget right="20" top="55" config="widgets/MapSwitcher/MapSwitcherWidget.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/> <widget left="0" top="0" config="widgets/HeaderController/HeaderController.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/> <widget right="1" bottom="1" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/> <map initialextent="11428023.5620323 7044712.37840232 11661407.1864131 7229241.03074607" fullextent="11282090.75 6883424.125 11723944.25 7320825.375"> <basemaps> <mapservice label="Frederick County" type="dynamic" visible="true" alpha="1" url="http://gis1.co.frederick.va.us/ArcGIS/rest/services/Publicsite/MapServer" /> </basemaps> <operationallayers> </operationallayers> </map> <!-- widgets organized into widget containers that manage close/open etc --> <!-- supported layout property options: horizontal(default)|float|vertical|fix--> <widgetcontainer layout="float"> <widget label="Bookmarks" x="400" y="60" icon="assets/images/i_bookmark.png" config="widgets/Bookmark/BookmarkWidget.xml" url="widgets/Bookmark/BookmarkWidget.swf"/> <widget label="Find an address" x="70" y="94" preload="open" icon="assets/images/i_target.png" config="widgets/Locate/LocateWidget_US.xml" url="widgets/Locate/LocateWidget.swf"/> <widget label="Louisville Police" x="590" y="300" icon="assets/images/i_police.png" config="widgets/Query/QueryWidget_PublicSafety_Louisville.xml" url="widgets/Query/QueryWidget.swf"/> <widget label="Search" icon="assets/images/i_search.png" config="widgets/Search/SearchWidget_Louisville.xml" url="widgets/Search/SearchWidget.swf"/> <widget label="Earthquakes (GeoRSS)" icon="assets/images/i_rss.png" config="widgets/GeoRSS/GeoRSSWidget.xml" url="widgets/GeoRSS/GeoRSSWidget.swf"/> <widget label="Draw" icon="assets/images/i_draw2.png" config="widgets/Draw/DrawWidget.xml" url="widgets/Draw/DrawWidget.swf"/> <widget label="Print" icon="assets/images/i_print.png" config="widgets/Print/PrintWidget.xml" url="widgets/Print/PrintWidget.swf"/> <!-- <widget label="My first widget" icon="assets/images/i_widget.png" config="widgets/Samples/HelloWorld/HelloWorldWidget.xml" url="widgets/Samples/HelloWorld/HelloWorldWidget.swf"/> --> </widgetcontainer> </configuration>
