var networkLayer= new Layer("my_url.../NaServer")
//make a request on the rest api to get all the details of the NAServer Layer
var details = networkLayer.getDetails()
// in the details, get the network_attributes : I can then get the several cost existing in my Network
var costs=details.network_attributes<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx"
minWidth="955" minHeight="600"
creationComplete="application1_creationCompleteHandler(event)">
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<fx:Script>
<![CDATA[
import com.esri.serialization.json.JSON;
import mx.events.FlexEvent;
import mx.rpc.events.FaultEvent;
import mx.rpc.events.ResultEvent;
import mx.rpc.http.HTTPService;
import mx.utils.ObjectUtil;
private var httpServ:HTTPService;
private function xmlResult(event:ResultEvent):void
var Info:Object = JSON.decode(event.result.toString());
trace(ObjectUtil.toString(Info.networkDataset.networkAttributes));
private function xmlFault(event:FaultEvent):void
var sInfo:String = "Error: ";
sInfo += "Event Target: " + event.target + "\n\n";
sInfo += "Event Type: " + event.type + "\n\n";
sInfo += "Fault Code: " + event.fault.faultCode + "\n\n";
sInfo += "Fault Info: " + event.fault.faultString;
trace(sInfo);
protected function application1_creationCompleteHandler(event:FlexEvent):void
httpServ = new HTTPService;
httpServ.url = "http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route?f=pjson";
httpServ.addEventListener(ResultEvent.RESULT, xmlResult);
httpServ.addEventListener(FaultEvent.FAULT, xmlFault);
httpServ.send();
</fx:Script>
</s:Application>
