Flex runtime error with Editor
1008
11-29-2010 07:01 AM
ADEade
Hi all,
Since this morning i'm blocked cause a runtime Flex error.
I try to create an Editor in a widget, with the following code :
<fx:Declarations>
  <esri:GeometryService id="myGeometryService"
         url="xyzxyzx"/>
 </fx:Declarations>
 <esri:FeatureLayer url="xyz" id="featureLayer"/>
 <esri:Editor id="myEditor"
     width="100%" height="200"
     geometryService="{myGeometryService}"
     map="{map}"
     featureLayers="{[featureLayer]}"/>
I can create polygons. But when I do a double click to terminate the polygon, the following error occurs in the Flex application :
[INDENT]TypeError: Error #1009: Cannot access a property or method of a null object reference. at com.esri.ags.components::Editor/drawTool_drawEndHandler() at flash.events::EventDispatcher/dispatchEventFunction() at flash.events::EventDispatcher/dispatchEvent() at com.esri.ags.tools::DrawTool/removeLayerEndDraw() at com.esri.ags.tools::DrawTool/map_doubleClickHandler()[/INDENT]
And next, all clicks in the map give errors like :
[INDENT]TypeError: Error #1009: Cannot access a property or method of a null object reference. at com.esri.ags.components::Editor/map_mouseUpHandler()[/INDENT]
It's very hard to debug because the error occurs in the Editor component...
Do you have idea ? What can I try to investigate this problem ?
Thanks in advance,
Antoine
ADEade
Can I know what is the property/method at the line 1776 in the class com.esri.ags.components.Editor ?I use the release 2.1.
Antoine
DavidTreat
Antoine,
Is your Feature Service based on data hosted in an ArcSDE geodatabase?  That is a prerequisite for the edit function.
Dave
