I would like to use the attribute editor component to create an attributed related record. But, I am not sure how to set this up. The Esri example of creating a related record does not use the attribute inspector, so I can't use that as my starting point.
I would like the user to select a feature, then click a button to create a related record. To create that related record, I would like to use the attribute inspector so I can use the default editing components, all my fields are domained.
As of now, I am just creating an object of all the attribues, creating a graphic, assigning that object to the graphic's attributes property, then using a feature layer to apply the edits.
