Hi, The function below only works on the first combo change event. The combobox is really not the problem. The data changes with the combo event, but for some reason the centerAt will not fire on the second change event. Has anyone seen this issue? protected function cbo_ZoomToTerritory_changeHandler(event:IndexChangeEvent):void
var extentString:String = cbo_ZoomToTerritory.selectedItem.data;
var extentVals:Array =extentString.split(",");
mainMap.extent.update(extentVals[2],extentVals[3],extentVals[0],extentVals[1]);
mainMap.centerAt(mainMap.extent.center);
