Can I change selected feature filled color in Flexviewer?
2393
11-17-2010 08:26 AM
CindyLu
I am trying to modify Flexviewer for one of my Flex application. Our client want to change the selected feature filled color for Select widget and QueryAttribute widget. Can anyone tell me where is the piece of code that I need to change for doing that?
Thank you very much in advance!
Cindy
CindyLu
I got it.
Change the following line to whatever color you want -
    private var graphicPolySym:SimpleFillSymbol = new SimpleFillSymbol("solid", 0xFF0000, 0.5, graphicLineSym);
Thanks!
Cindy
DasaPaddock
I'm not sure which widgets you mean, but the Query widget does let you change the symbology. See the bottom of the help for the Query widget at:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html
