Automatcially zoom to selected records (SFV 1.x)?
1002
6
07-28-2010 06:00 AM
BoCastillo
When a user performs a search, I want the record(s) to be automatically zoomed to. Due to the way the click on the selected record and zoom in feature works in the SFV by using a set scale, this may not work so well for automatically zooming in on multiple records. Is it possible to have it zoom in automatically for all records and use a new set scale or just one returned record? I've tried searching the old and new forums but I haven't been able to find any samples.
KeithPalmer
You're in luck Bo.  I needed to do this today too so I pulled together the logic from various samples (yes, I hate reinventing the "wheel"):
private function zoomSelected():void
if (graphicsLayer.numGraphics > 0)
  var pt:MapPoint = new MapPoint();
  var extSelected:Extent;
  for each (var selgra:Graphic in graphicsLayer.graphicProvider)
        pt = getGeomCenter(selgra);
  //Calculate the Selected Feature Extent
          if (extSelected == null) {
                 extSelected= new Extent(pt.x,pt.y,pt.x,pt.y);
            } else {
               if (pt.x > extSelected.xmax) {extSelected.xmax=pt.x;}
               if (pt.y > extSelected.ymax) {extSelected.ymax=pt.y;}
               if (pt.x < extSelected.xmin) {extSelected.xmin=pt.x;}
               if (pt.y < extSelected.ymin) {extSelected.ymin=pt.y;}
    map.extent= extSelected.expand(2);
-Keith
BoCastillo
Keith,
Thank You! It works perfectly!
MayJeff
Can you show me where to add the code to make it to work?  I tried it on the SearchWidget.mxml for SFV1.3.
Thank you.
May
BoCastillo
May,
You can add Keith's code almost anywhere in the SearchWidget.mxml, as it is a stand alone function. This alone won't be enough and you will need to set up a section of you code to actually call up the "zoomSelected" function.
I added this small section of code near the end of the "createRecordData" function:
if (featureSet.features.length > 0)
     zoomSelected();
Right before this line of code:
return recAC;
This executes the "zoomSelected" function when the search results are generated and will not execute the code unless there is at least one selected feature.
MayJeff
Thank you very much.  It works.
MikeHouts
Im have been trying to make a model in 9.3 that will select a polygon by attributes and then zoom to the selected.  Once created I plan to add the tool to a .net web app to facilitate user quarry and zoom capability.
I have the selection part ok, but cant get the zoom to selected.  I found the python script to do in in 10, but our server is still using 9.3.
Any help with python code or python code to call a VB script (and the VB script) or if there any other way would be greatly appreciated.
Thanks, Mike
import sys, string, os, arcgisscripting
## create the geoprocessor object ##
gp = arcgisscripting.create()
## Load required toolboxes ##
# gp.addtoolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx
# set workspace
# arcpy.env.workspace = "C:/temp/"
# mxd = MapDocument('CURRENT')
# df = ListDataFrames(mxd,"Layers")[0]
# Script arguments
section = gp.GetParameterAsText(0)
township = gp.GetParameterAsText(1)
range_ = gp.GetParameterAsText(2)
range_dir = gp.GetParameterAsText(3)
# Local variables:
PLSS = "PLSS"
#### Use the SelectLayerByAttribute tool to select a Section
gp.SelectLayerByAttribute_management(PLSS, "NEW_SELECTION", "\"SECTION\" = "+section)
gp.SelectLayerByAttribute_management(PLSS, "SUBSET_SELECTION", "\"TOWNSHIP\" = "+township)
# arcpy.SelectLayerByAttribute_management(PLSS, "SUBSET_SELECTION", "\"TOWNSHIP_D\" = S")
gp.SelectLayerByAttribute_management(PLSS, "SUBSET_SELECTION", "\"RANGE\" = "+range_)
gp.SelectLayerByAttribute_management(PLSS, "SUBSET_SELECTION", "\"RANGE_dir\" = "+range_dir)
#Zoom to selected features in the map
--------- HELP NEEDED HERE !! -------------
# Clear the selection and refresh the active view
gp.SelectLayerByAttribute_management(PLSS, "CLEAR_SELECTION")
gp.RefreshActiveView(
