Attachment Relate Widget
248
05-11-2011 03:11 AM
JohnMcConalogue
I have the Attachment relate widget up and working. Fantastic widget Robert.
I am displaying data that has a Geometry Type: esriGeometryPoint it works fine.
If I point towards data that has Geometry Type: esriGeometryPolygon nothing is displayed.
Is this widget configured to only work with Points and not Polygons or do I need to change something?
J.
RobertScheitlin__GISP
John,
    Several people have this working with polygon layers. Maybe you should post your xml.
JohnMcConalogue
Hi Robert,
Thanks for the reply. I'm pretty new to all this ArcGIS, what XML are you referring to.
J.
John,
   The xml file that you customized for your data (i.e. IWT_???.xml).
JohnMcConalogue
Thanks Robert.
I got that working.
