I was wondering if there would be an AllSource Add-In similar to the ArcGIS Pro Add-In available for .NET?
Add-ins will be supported for AllSource by using the ArcPro SDK. That said, configurations aren't going to be support for a while.
Perfect thank you @DrewYoung! What do you mean by "configurations"? Sorry. I'm fairly new to ArcGIS Pro SDK for .NET.
No worries!! The Pro SDK can allow you to set certain configurations to change the look and feel of the application. You can simplify it down to a single button on a single ribbon if you wanted!
Here's a blog that gives a good read-out of how it all works:
https://www.esri.com/arcgis-blog/products/3d-gis/3d-gis/introducing-arcgis-pro-sdk-configurations/
Perfect! Thank you so much @DrewYoung 😁
@DrewYoung Quick question? Related to ArcGIS Pro SDK for.NET. Is there a built in "Host" for the Add-In Module. I am trying to implement Dependency Injection, but nothing seems to work.
Hi @diegom_geoowl this will be offered in the upcoming release for ArcGIS Pro SDK for .NET
