I am trying to project a feature class in ArcMap using a project tool and I have hundreds of attachments files included in this feature class, When I project the data the new feature class does not include the attachments files, In workspace > environment > geodatabase I checked box to 'maintain attachments’, Is there a way to transfer or retain the old attachment data from the old feature class into the new feature class? Thanks- I am using ArcMap 10.8
ArcMap does not support attachments with the Project tool. You can see the tools that maintain attachments here:
https://desktop.arcgis.com/en/arcmap/latest/tools/environments/maintain-attachments.htm
ArcGIS Pro does support maintaining attachments with the Project tool:
You can do this workaround in ArcMap:
https://support.esri.com/en/technical-article/000011569
I'd recommend just making the move to ArcGIS Pro
