no feature is created from a model
1554
13
05-22-2020 08:06 AM
MedMZOURI
New Contributor III
Hy guys..I have created a python script and a model which creates a feature (a square) in a layer given X and Y coordinates of center. of the square...it works on Arcgis desktop so I published it as a geoprocessing service and added it as a custom widget on Web Appbuilder , and when I run it it runs without error ..But NO FEATURE is created in my layer..
I have checked everything is okay..my map is a feature layer uploaded in my arcgis server..editing is enabled , creating , deleting and deleting are enabled too..So where is the error??
MedMZOURI
New Contributor III
Can you tell me please in what stage in the python script should I be referencing my hosted layer's REST URL, because I tried to put the REST URL instead of the local path in "arcpy.da.Editor("https://services8.arcgis.com.......") and it turns error
MichelleBrake
New Contributor III
Here are some resources to help you with what functions are available and referencing a service:
ArcGIS API for Python | Editing Features
ArcGIS API for Python | Updating features in a feature layer
Using Python to Write Features to a Feature Service
If things are still unclear are reading those I would recommend posting to a python specific group/community like ArcGIS API for Python‌ or Python‌ to get more targeted help.
Michelle
geojobe.com
MedMZOURI
New Contributor III
Thank you Michelle..so , what I understood from your answer is that the use of ArcgGIS API for python is essential..because so far I haven't used it , I've only used simple python scripts within ArcGis desktop then sharing them as Geoprocessing services.
MichelleBrake
New Contributor III
Not necessarily. The issue you were running into was functions to make edits on services, not local data, and referencing services in the script. Those resources I provided where to help with the python functions for both as it is a bit different than working with local tasks and data.
Michelle
geojobe.com
