How to show polygon boundary in address locator search results
1075
10-06-2019 04:27 AM
YENERTURKMENOGLU
Hello Everyone,
I have created an address locator from polygon data. When I search for a polygon name, the locator is showing polygon center But I need to show polygon boundary. I couldn't find a setting for this. Does anyone have any idea? #create address locator‌
ShanaBritt
Yener:
Geocoding is always going to return a point result. Where are you using the locator?
If you are using ArcGIS Pro, have you tried configured layer search in the Locate pane or searching all layers in the map using the Locate pane?
-Shana
