how to convert .asc to .xyz
17012
07-21-2012 05:55 AM
yuehuang
Hi:
I have Lidar data with .asc format.
ASCII to raster can convert my data to raster, is this raster DEM?
I was try to build a terrain then create a DTM, but the frist step I should convert my .asc to FeatureClass, However, the "ASCII3D to FeatureClass" only allow .xyz .xyzi and generat file formats.
what should I do ?
thanks lot and lot ,please help me!!
Tags (1)
RobertSchaffer
.asc is best used in autocadd. You can create a surface then export that surface out as a land xml and import it into gis. This is the cleanest way I have found.
PavanYadav
Hi:
what should I do ?
I know this is an old post, but if you are still working on it, can you send me a sample data at pyadav at esri.com. Or, reply to this post with a screenshot of a sample file showing the header information of the data.
Thanks
Pavan
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
RavinHasseea
Hi I am also trying to build a terrain given a set of .ASC files. The ASCII3D to FeatureClass doesn't work in this case.
Would I need Data Interop or FME to create XYZ from ASC file first ?
Any suggestions ?
Screenshot of .ASC file
