Fly by animation in ArcGlobe
2292
04-07-2014 02:04 AM
808707
I've been having a go a making a fly by animation in ArcGlobe using a DEM and aerial imagery.
Using 'Create fly by from path' I've managed to create an animation.
However the camera isn't placed quite correctly and I would like to hopefully get the camera to pan around as it moves around.
Is there any way to do this?
Thanks for any help.
JeffreySwain
You would be probably better off simply adding the shots you want to achieve and then let the animation process 'move along the path.'  So if you would like the animation to 'look around' simply choose the views you want it to take.  The animation process will smooth out the turning and the path based on the order of the shots you select.
Thanks jbswain that's working alot better now.
I have an aerial imagery draped over a DEM. I was wondering the best way to rotate around the image at a fixed point. It gets a bit choppy when I try to do it manually.
