Filter Building tool greyed out; layer missing statisical information
1302
02-10-2020 07:09 AM
DavidBrooks5
Im trying to create a Building Scene Layer Package from a 2020 Revit model in Pro 2.5.
One of the model families (Generic Model) has incredibly complex geometries in it, that i want to filter out of the resultant SLPK. However, when i select my model in the Contents panel, the "Building Filter" tool isn't available from the "Manage" ribbon (it should be).
I have managed to find out (by adding the tool to the quick access ribbon) that this tool is greyed out, and hoevering over it yields the following tip: This Command is currently disabled: The layer is missing statistical information.
Is that something I can resolve? Or is there something fundamentally wrong with the Revit file? Or has Pro 2.5 been released with Revit 2020 functionality, without ensuring all Pro tools are compatible?
DA_BIM-GIS
Hello David,
My understanding of the issue posted by you is that you would like to published a Building Layer (BL) without any Generic Model elements from a Revit file (Revit 2020). To accomplished this on Pro 2.5 this is my recommended workflow
  1. Run the GP too (BIM File to Geodatabase)
  2. Delete the Generic Model Feature class from the dataset
  3. Run GP Tool (Make Building Layer)  - Scene needs to be open
  4. Run GP Tool Create Building Scene Layer Package
  5. Upload the scene layer package to AGOL or portal.
You can create model to achieved this workflow.
best regards,
David
Andrew--Johnson
Hi David,
The building filter is only available on building scene layers for 2.5 so that is why it is grayed out for the building layer (from revit). Currently the only workflow then is to add the filter after the building scene layer package has already been created.
I do have some good news though in that we have worked with the CAD team to add this functionality in 2.6. The manage tab for building layers (from revit) will include the building filter button along with a button for generating statistics on the building layer. I can keep you posted when the ArcGIS Pro 2.6 beta comes out if you want to check out the functionality before final release in June (tentatively)
thanks,
Andrew
Andrew--Johnson
Also David, I just saw your comment in another thread and there is actually a different workflow you can use to remove the Generic Model from the building layer. My colleague from the CAD/Revit team will be posting in that thread shortly.
thanks,
Andrew
DA_BIM-GIS
Hello David,
best regards,
David
DavidBrooks5
Thank you for all your excellent comments and solutions. I can confirm that the above approach works a treat. And I'm glad I wasn't going made when trying to filter the data.
In the end, I ran the Create Bounding Volume tool on the highly complex models, to made crude versions, and then swapped out the mulipatch before generating the SLPK building package.
My next challenge is that some of the model elements from Revit appear to be offset in the x y and z from the main bulk of the model (up to kilometres away in some cases. This potentially implies that they aren't referencing the base/survey points correctly somewhere between Revit and Pro.
