expensive queries when using webscenes
472
10-07-2025 06:04 AM
JElsinghorst
Hello,
the webscene viewer (portal/home/webscene/viewer.html) generates queries that are very costly for our database. There queries often just and in an error or timeout and affect other queries running at the same time.
GET/server/rest/services/LoD2_2D/LoD2_2D_2024/FeatureServer/0/queryf=json&outFields=*&outStatistics=[{"maxPointCount":100000000,"maxRecordCount":100000000,"maxVertexCount":83334,"outStatisticFieldName":"exceedslimit","statisticType":"exceedslimit"}]&returnGeometry=false&spatialRel=esriSpatialRelIntersects&where=1=1
This results in this database query (SDE on ms sql server):
SELECT 1 AS exceedslimit FROM SDE.LoD2_2D_2024 HAVING (COUNT(*)>100000000 OR SUM(SHAPE.STNumPoints())>83334)
In our case there are over 50 million building footprints in this layer which the database has to read all from disk to count them and the number of points of each geometry.
How can this be avoided?
OwenGeo
Esri Notable Contributor
@JElsinghorst - Sorry, but this is not in my area of expertise. I think you are more likely to get help with this question by posting on one of the 3D boards.
Owen Evans
