Buildings disappear in ArcGIS online scene
1790
12-05-2017 02:05 AM
Ystad1
I have created a number of 3D buildings using SketchUp and ArcGIS Pro which are stored as a multipatch. All buildings are visible in ArcGIS Pro and with the correct appearence. I have created a scene layer package and published to ArcGIS online. When I open the layer in a scene a number of the buildings are missing and a number have got white roofs and not the colour which I see in ArcGIS Pro. When I view the multipatch in a 2D map in Pro/Desktop/Catalog the missing buildings are visible. I don't think it has anything to do with the base elevation value as most buildings as visible.
Any ideas?
DanPatterson_Retired
is there anything common amongst those buildings? common property? date created?
Ystad1
It was the buildings I created yesterday that aren't visible. I have just tried replacing a building in a new multipatch with a SketchUp model and publishing and it worked. Seems like my other multipatch is corrupt. For the buildings with white roofs it seems like I need to set a colour on the reverse side of the polygon (inside the building) so that it is not white when published on ArcGIS online.
so all is good then
