Hi, can anyone help me understand the solution to these warnings? Tool runs fine locally, but when I publish to server 11.3 it fails and the server logs show these same errors.Cannot find the parameters for these tools e.g. Distance does not have a filterType in the settings anywhere.In the tools properties section there is a column called Filter where I have tried to state none or output as a polygon, line etc depending on the feature type. This hasn't helped.It's all very confusing. Help section isn't clear either on how or what to do to resolve these warnings.Using PRO 3.5.2 with toolbox version 3.3 & enterprise version 11.3Thanks
the help topic
003506: At version <value>, the "<value>" tool's "<value>" parameter's filterType has changed.—ArcGIS Pro | Documentation
suggests using
Analyze Toolbox For Version (Data Management)—ArcGIS Pro | Documentation
did that reveal anything?
Hi, no I found that as well and it did nothing useful.
Tech Support is your best bet then since the only reference to 003506 on the public facing web site just references the help topic in its various incarnations
Esri Support Search Results
I might have to...all these different versions of toolboxes that you can save/convert to, and enterprise and pro versions...and they all have their own nuances it is all extremely complicated now. I just wish there were some more solid pointers in how to fix these errors instead of some generic descriptions...yes I know it's failed, you don't have to state that...what I want to know is how to fix it!
good luck
