Shapefile reprojection issues
3671
06-30-2014 03:49 AM
EdwardYorke
Dear all
I'm currently working with some shapefiles for Mars data and have reprojected a geology shapefile to a THEMIS layer. The Projected Coordinate Systems are the same, however, the extents are not. It seems that after projecting the shapefile, the extent changes and centers the shapefile to the THEMIS layer. So I end up with a tiny shapefile about 1 pixel in size in the centre of my rasters.
Any help would be greatly appreciated.
MelitaKennedy
Esri Notable Contributor
Did you use the Project tool or ArcMap (and then export the data using the data frame's coordinate system)? Or did you use the data's property page from ArcCatalog or the Define Projection Tool? If the latter, that updates the metadata only and doesn't permanently change the data's coordinate system.
Melita
EdwardYorke
Ah thank you! I just discovered this myself but you have explained why this happens. I updated in the catalogue and it wasn't updating the extent. Gold star!
