Composite Geocoder Return Results
4249
11-30-2014 05:38 PM
FlorenceFang
Hi all,
I've set up a composite locator for streets which is in Single House then Dual Range Road order.
Sometimes the Single House geocoder will return a result with a lower score than the Dual Range Road geocoder (i.e. single house score will be 90, and dual range will be 100).  However, because the Single House is the first in the series, it returns the result with the lower score (more often than not in the wrong place).  Is there anyway I can get my geocoder to return the highest score, even if it's coming from the second tier gecoder?
Thanks for the help!
Cheers
Florence
Tags (1)
NathanLowry
Partial responses to this question can be found at StackExchange: ArcGIS composite locator results out of order
NathanLowry
